1968 radiator support bushings don't fit!
Old Jul 23, 2017 | 04:49 AM
a-merry-can's Avatar
hi guys, I'm having trouble fitting my core support. I'm on my second set of bushings and still no joy. As I understand it, the big part is supposed to stick through the core support and the little cap piece fits on top then the washer. None of the bushings I've gotten to date have fit through the hole in the support. Before I enlarged that hole, I thought I'd get some opinions. Go!
Old Jul 23, 2017 | 06:19 AM
If the hole is too small in the core support, you can either make it bigger or find a set that looks like this.
Old Jul 24, 2017 | 06:53 PM
Ordered. Thanks!
Not sure how I ended up with 2 sets that didn't fit. Oh well.
Old Mar 17, 2020 | 07:47 AM
Billyaxe's Avatar
I just had the same situation. They wrong bushings which are GM 1961-77 didn’t fit. I wound up shaving some of the rubber off. —Billy
Old Mar 17, 2020 | 08:40 AM
allyolds68's Avatar
Just out of curiosity where did you get the bushings from? The square bushings above are correct for 68
Old Mar 17, 2020 | 06:14 PM
Billyaxe's Avatar
I bought them from Jurassic Classic Auto parts on eBay. I guess they’re wrong in their description.
Old Mar 18, 2020 | 05:53 AM
FYI, any vendor that lists parts for a "GM" typically means "Chevy". Those parts may or may not be correct for an Olds, but chances are, they are not. That's like every ad that says the parts fit a "GM 350"... they are NOT going to fit an Olds 350.
Old Mar 19, 2020 | 05:47 AM
Billyaxe's Avatar
Lesson learned. Thanks. —Billy
tgilligan
Body work
May 27, 2017 06:06 PM
gasserdays
Nov 20, 2014 07:10 PM
Pacecar
Body work
Aug 27, 2012 06:44 PM
mmcilroy
Jul 8, 2010 04:46 AM
jeffs 89 cutlass salon
Sep 22, 2007 05:28 PM
