70 Cutlass Convertible
Old Apr 4, 2014 | 03:14 PM
72xw30's Avatar
Not mine, but is about 10 minutes away.
Can check it out if someone is interested.
Cheers,
Sam
It's a 442 from the VIN!
http://ontario.kijiji.ca/c-ViewAdLar...eyword=Cutlass
Old Apr 4, 2014 | 06:32 PM
tru-blue 442's Avatar
Old School Olds
He must have pulled it. (No longer available.)
It will probably come back as a 442. That,
or someone snagged it.
Old Apr 5, 2014 | 10:01 AM
72xw30's Avatar
Its on ebay now.......
http://www.ebay.com/itm/Oldsmobile-C...US_Cars_Trucks
Update:
I went and looked at the car this AM. It is a nice looking car but will require a full resto for sure. It has rust issues around the windshield, bottom of windshield and also the header panel. The dash in the radio area has been cut as well to fit the aftermarket unit. The floors are solid and trunk area is ok. Something with the VIN tag doesn't look right to me????
The 455 is from a 1973, VIN derivative - 33MXXXXXX with GA heads....., 1972 carb , 7042251, has its original 70 OG tranny. The trans still has the black OG tag on the passenger side. I couldn't find the code on the rear end as it is coated with grime etc.....
Also, it's another "Z" coded car on the cowl tag and yet again a Canadian Connection.
The car spent a lot of time down in NC but has always been registered up here in Ontario.
Here are some additional pictures......
Let me know if you require more information. The car is less than 10 minutes away from me.
Cheers,
Sam
ros6872
Oct 30, 2015 09:41 AM
ros6872
Oct 31, 2014 05:04 PM
70SXchris
Feb 24, 2012 05:02 AM
70SXchris
Mar 25, 2011 09:31 PM
djsoldzparrts
May 22, 2008 12:53 AM
