1968 Cutlass S
1968 Cutlass S
Located in Pflugerville, TX 78660Selling my 1968 Oldsmobile Cutlass S. It has a non numbers matching 350 rocket with a TH350 that i decided to be from a 72 Oldsmobile. The interior is in really good condition for the age. I have a clean Texas title and current registration. I've done a lot of work on it and it is a solid driver but not perfect. Minimal rust. I have the missing emblems and an additional set of wheels (SS1 style). $14,000 obo, thanks for looking.
The good(new):
Battery
Motor mounts
Oil pan
Transmission gasket
Brake work, new pads and shoes
Heater core
Thermostat and housing
Full front end suspension rebuild. Over 2k in new parts
-UMI performance tubular upper and lower control arms with poly bushings
-QA1 sway bar
-QA1 pro coil over system adjustable coilovers
-replaced tie rods, idler arm, center link
The bad:
Heater controls are broken
Brakes pull a little when braking
Hood and doors need adjusting
Small rust hole on driver's door
Paint is there but not great
Cracked dash
Fuel gauge is off( most likely needs a new sending unit)
The good(new):
Battery
Motor mounts
Oil pan
Transmission gasket
Heater core
-QA1 sway bar
The bad:
Cracked dash
gearheads78
Dec 7, 2017 07:16 PM
