1970 w31
Old Jul 3, 2020 | 04:26 PM
4+4+2=10's Avatar
1970 w31
Seller has no documentation. See anything in the pics that would disqualify it as legit? I don't like the quality of the striping, especially on the hood, otherwise a nice looker.
ebay W31
Old Jul 3, 2020 | 05:01 PM
1970supremevert's Avatar
not that it make a difference , I thought the non a/c cars mounted the alt on the right side?? , not sure if the 350 was different,
Nice eye candy
Old Jul 3, 2020 | 09:29 PM
Factoryhotrod's Avatar
Approach with caution.
Old Jul 3, 2020 | 10:01 PM
v8al's Avatar
Registered Olds Owner
One of the pictures on the above URL is of a VIN (see below). Can anyone me where this VIN is located? Is this the transmission? Why is there blue paint?
Where is this VIN located?
Old Jul 4, 2020 | 05:34 AM
Johnd's Avatar
I talked to the guy before it went up for sale. The car does not have the original motor which is why the alternator is on the wrong side. Also, it has 71/72 fenders which were a turn off for me on a 1970 car
Old Jul 4, 2020 | 06:51 AM
cherokeepeople's Avatar
thats the block vin number,the round thing above it is a soft plug in the head.but what is on the soft plug is baffling me,kinda looks like a penny.
Old Jul 4, 2020 | 07:18 AM
I think that the little button in the middle is used by engine re builder & warranty companies to determine if the engine has been overheated
if overheated it melts
Old Jul 4, 2020 | 07:33 AM
heat tab
IMPORTANT HEAT TAB INFORMATIONTECH NOTE
Heat Tabs are installed on engines to detect abnormally high engine coolant temperature. The Heat Tabs are placed on the cylinder head(s) and on the engine block in an area that is in direct contact with the engine coolant. They can be found mounted on the casting surface or inside of a freeze plug.If the engines operating temperature reaches or exceeds 250° F the center of the Heat Tab will melt and flow out. This is a positive and certified method of determining whether the engine has reached a temperature beyond the normal operating range, thus voiding the warranty. The warranty is also void if the heat tab shows any signs of being tampered with or is removed from the engine.
Old Jul 4, 2020 | 08:36 AM
briane's Avatar
Appears to be pretty clean underneath, however no parking brakes (cables missing). Why would that be? Hood screen gone. Fan shroud hacked up. Black wheels, 442 taiillamp lense and deck stripe. Seems like a lot of items to negotiate over.
Old Jul 4, 2020 | 08:43 PM
v8al's Avatar
My point is that the engine appears to fully painted gold in all the other pictures. If that is the engine VIN stamp why is it painted blue? Additionally it was already stated above that the engine is not original so why would they show the engine VIN when there's no way it should match?
4-Speed
Cars Wanted
Jan 17, 2020 01:45 AM
Stefano
Feb 7, 2017 06:51 AM
rallyredw31
Aug 3, 2016 07:25 PM
davebw31
Apr 15, 2014 09:39 AM
olds w-31
Jul 29, 2010 10:27 AM
