Well, after thinking about it for some time, 1 have decided to see if someone else would like to enjoy my 1969 442. I am just not able to dedicate the time and effort to really enjoy it like I should. The 3 year restoration was completed in 2011. Very few miles since then. Every component on the car has been restored, refurbished or replaced with new. This was a frame on restoration, but all suspension was removed and rebuilt (front and rear) The underside of the body and the frame were cleaned up and painted. All nuts, bolts and screws were removed, cleaned up and reused. Body is extremely straight with patch panels on one fender and one rear quarter. Very little filler on this body. Door, hood and trunk gaps are perfect. This car is 95% stock with only a cam change and a anti-spin unit added to the stock rear gears. If you are looking for a very nice, real 442, you will not be disappointed.
Car is located in central Texas near Waco. I would rather you see the car in person or have someone else inspect the car. If you are interested, PM me your info and I will get in touch.
I have sold a lot of cars but all of them have been local. No special financing or trades.
DETAILS
1969 442 - 344879M425958
Trophy Blue Basecoat/Clearcoat
White Vinyl Top
Blue Legendary Int
Numbers matching 400 325 HP
Numbers matching TH400
Stock rear (3.23) with Anti-spin added
Original bumpers rechromed by Ogden
AC, PS, PB, AM/FM, & Light Group
Driver & Pass Mirrors
PROBLEMS/NEEDS
AC needs to be evac'ed and recharged. The POA valve stuck about 2 years ago. It was replaced with a new valve set up for R134, but never recharged.
Clock only worked for about a year after restoration and never fixed
Driver side rear window has a slight blemish in the glass. Did not notice until interior was in. I have a perfect glass, it just needs to be in installed.
MORE INFO
If you are interested in more info and pictures, go look at my post on the car.
THREAD
My First Olds Restoration – 69 442
rsandhoff Feb 5th 2011
ENGINE INFO
Block - 396026G bored .030 over
all new plugs, HC (4bll) pistons, moly rings, Clevite bearings
Heads - added hardened exhaust seats, new valves, springs/retainers, rocker arms and bridges,
push rods, lifters
Cam - new from Andy at Olds Performance Products
grind - Dur@50 Int 224 Exh 231
Lift Int 491 Exh 488
Crank - +.010/.010 just to clean it up
New balancer, water pump, etc
Carb – Carb for a 69 4-speed, Rebuilt by forum member
Dist.- stock converted to Petronix
Reason: Sold
