72 Cutlass Supreme, Yellow, 403. $14,900
Old Aug 25, 2006 | 04:06 PM
190hpkilla
Guest
Posts: n/a
1972 Cutlass supreme with 90K on the body. $14,900
call 347-392-1491
All of the following was just installed over the winter.
I had the car for 6 years. Pictures can be seen here..........
http://www.cardomain.com/ride/2423962/1
No Rust. Beautiful yellow paint. Racing seats. Gauges etc. Too much to list. You need to see the car. Turn the key and go. Runs on 93 with no overheating in traffic. Since those pictures I have added an external fuel filter and sump but some pictures dont show it.
403 Bored 30 over
Factory Flat pistons and rods
Speed pro rings
Reconditioned crank. 10 over 10 under
Stock oil pump
Mondello Cams
Castings #7 Cylinder Heads. True 9.6 to 1 compression.(Very high for olds)
Big Block Size Valves
Manly Valves
Mondello Valve springs(dual) and lifters
Comp Cams Roller Rockers, push rods and guide Plates
Arp rocker studs 3/8
Edelbrock Performer RMP Manifold
Demon 750 Double Pumper Carb
3200-3600 Stall converter
Anti balloening plate
Freddy Banks Turbo 350 Tranny
Gm 10 Bolt Posi 3:73 Gears
Holley fuel pump
Gas tank sump
Hocthkis boxed lower arms
Lakewood anti hop bars
Trick springs front
Lowered Rear Springs
Summit Line Locks
B&M pro stock shifter
Bluemeanie
Feb 20, 2014 07:09 PM
Nop
Jan 29, 2014 10:01 AM
Gator69olds
Jul 24, 2012 08:39 PM
iuhoops83
Feb 1, 2011 08:48 AM
iuhoops83
Jan 3, 2011 05:43 AM
