1965 cutlass
Old Aug 18, 2016 | 08:19 PM
junkman005's Avatar
1965 cutlass
http://milwaukee.craigslist.org/cto/5739591673.html
Old Aug 19, 2016 | 06:13 AM
Originally Posted by junkman005
Nice looking car, good luck. FYI, that's not a Powerglide, it's a Super Turbine 300, also called the Jetaway by Olds. Other than having two speeds, it has nothing in common with a PG trans.
Old Aug 19, 2016 | 04:26 PM
junkman005's Avatar
Thank you , i had no idea about the trans not being a power glide because the guy i got it from said it was a power glide. is there any way to know for sure what it is because i dont wanna miss lead anyone. funny i was taken pics to load for the add and realized that i took like 40 pics and was like o boy lol
Old Aug 19, 2016 | 04:57 PM
If it's a two speed trans behind an Olds motor, it is a Jetaway. Old never used a Powerglide. This is a common misconception, since the Chevy-centric world thinks the PG is the only two speed trans that GM ever made.
Old Aug 20, 2016 | 08:52 AM
TripDeuces's Avatar
Since you are trying to be correct are you sure it's not a 330CI engine instead of the 350CI?
Old Aug 20, 2016 | 09:17 AM
The oil fill tube is 1968-later. Yes, I realize the tube can be changed, but it's a lot more common to install a replacement engine.
Old Aug 20, 2016 | 03:39 PM
junkman005's Avatar
its a 350 i swapped the motors the 330 is right now sitting in the drive way under a tarp (has internal crack in block) thats why i swapped it out. i would have put the air conditioning back in but the bracket didnt fit over the crome valve cover. but i do have the air conditioning and gold valve covers for it and a few extra parts like replacement grill and some i guess 442 side molding but i did not want to put it on the car. its a 1970 olds 350 rocket in there now with 60,000 original miles on motor i got to see the documents from the previous owner of motor showing me the miles. but since i did not get the documents from him it dont really mean anything lol
mosch1888
Feb 27, 2022 04:45 AM
2blu442
Jan 13, 2013 05:19 PM
BIGBAD455
Cars Wanted
Feb 1, 2010 07:17 PM
TECH9TWISTA
Mar 14, 2007 11:47 PM
Stacey
Mar 11, 2007 03:47 PM
