1964 Olds 98 4 Door Hardtop $2500 Loaded with Options, Nice Driver!!!
Brenden used to be active on this site and I've talked with him through email. I believe he did restoration work on this car through his High School auto shop class, including rebuilding a 1962 394. As happens to many of us, life changed and hes wanting to sell his car. This is a sweet deal for someone interested in a land yacht. He's got receipts showing close to $9,000 spent on the car, but has been dropping the asking price for about a year and is now down to $2500. Located in Klamath Falls Oregon, dry high desert environment. Check out pictures on the Craigslist ad:
http://medford.craigslist.org/cto/2694441922.html
John
John
It's not my car, but yes it's still for sale. I can't believe nobody has bought it yet
But here's the most recent Craigslist ad:
http://klamath.craigslist.org/cto/2822966750.html
In case the ad expires before you can call on it I've copied the ad below. The photos didn't come across, but you can read his text and see the photos on Craigslist. John
1964 Oldsmobile 98, 4 door hard top. pearl white paint, has all original chrome in good condition, won 2nd place in the Kruise of Klamath 2008, student class. Owned since 2007, invested roughly $9,000.00. I have all receipts
STOCK:
power brakes
power windows
power steering
power bench seat
tilt steering wheel
3 speed column automatic
original blue interior (missing door panels, have them but they are water damaged)
glass is all good except for front passenger window ($60 from Oldsmobile restoration catalog)
speedo works
gas gauge works
new weather stripping in trunk and above windows
NEW:
tires (Les Schwab)
brakes + master cylinder
4 core radiator (built to OEM specifications)
transmission radiator
K&N 14" circular air filter
new bulbs (from behind the dash to around the outside)
tri bar low beam headlights (conversion to H4 bulbs)
rebuilt distributor
MSD coil
spark plug wires
spark plugs
Jegs Holley style street fuel pump
Mr. gasket cool can
summit fuel pressure regulator
liquid filled fuel pressure gauge
alternator
exhaust new turbo mufflers, piping and tips (Midas)
gear reduction mini starter
new power steering hoses
electric fan and shroud
jagermeister coolant catch can
voltage regulator
duralast gold top battery
energy suspension anti sway bar bushings
triple gauge pod and gauges (water, volts and oil pressure)
Fresh built engine:
1962 394c.i. V8 6.5 L
Karl's Machine Shop did all the machine work
bored .030 over
decked block
polish crankshaft
external balanced crankshaft
valve grind
new valve seats
1 cylinder was sleeved
mild street cam from Schneider's Racing
rebuild kit including pistons from mad dog racing
i have tons of pictures of the engine build for proof
as of right now it has an Edelbrock 4 barrel carb on it but it will NOT be included in the sale I do have a 600cfm Holley that will be included along with the necessary adapter plate. NEED IT GONE. just bought a truck and cant afford both vehicles asking $2600.
call or text
Brenden
541.810.3511
•it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2822966750
No contact info? if the poster didn't include a phone number, email, or
other contact info, craigslist can notify them via email.
But here's the most recent Craigslist ad:http://klamath.craigslist.org/cto/2822966750.html
STOCK:
power brakes
power windows
power steering
power bench seat
tilt steering wheel
speedo works
gas gauge works
NEW:
tires (Les Schwab)
rebuilt distributor
MSD coil
spark plug wires
spark plugs
Mr. gasket cool can
alternator
voltage regulator
Fresh built engine:
bored .030 over
decked block
polish crankshaft
valve grind
new valve seats
call or text
Brenden
541.810.3511
Holy chit! That saddens me that, that car has not been grabbed up for that, steal of a price! I have a 64 Starfire that is in a little better condition than that, and I wouldnt think of letting it go for less than 10K. Wow, is it that rough out there?
Oldsrick, if you buy this car please let us know.
64OldsStarfire, yeah the economy is bad. But it seems like someone should have the extra money to pick it up. I'd use that as a daily driver in a heartbeat if I didn't have the 1967 Cutlass moredoor that I'm using now.
John
John
64ninetyeight64
Feb 14, 2015 06:35 AM
19magic73
Jan 12, 2015 07:41 PM
STR-8_CHARGIN
Nov 12, 2012 01:24 PM
