Care and Appearance Washing, waxing, paint care products, etc.
aluminum intake
Old Jan 24, 2012 | 05:44 PM
72hurst's Avatar
aluminum intake
I have an aluminum intake that I can't seem to get clean. It doesn't have any oil or girime it just doesn't look clean. As if it had some sort of oxidation. What is the best way to clean it?
Old Jan 24, 2012 | 06:57 PM
alek72us's Avatar
Olds Dreamer
if u can take it off have it sand blasted then clear coated. or u can try a wire wheel or wire brush.
Old Jan 25, 2012 | 04:23 AM
firefrost gold's Avatar
You can try some aluminum wheel cleaner with muriatic acid in it alittle goes along way. Then top coat after it is dry .
Old Jan 25, 2012 | 04:45 AM
Dave Siltman's Avatar
If you want a truely factory appearance send it to Jerry MacNeish at Camaro-Highperformance. If it is in need of any repair he can handle that, too. Depending on what kind of intake it is (factory vs. aftermarket) the cost to re-furbish might be more than it's worth.
Jerry's work is the best and is has been judged as such.
Old Jan 25, 2012 | 07:25 AM
frankr442's Avatar
I had mine glass beaded (sand is too violent). Every couple of months I wipe it down with GM heat riser lube #88862627. It gives it a nice natural sheen and keeps it from oxidizing. I love that stuff, it cleans and its the best lube I've tried. I use it on the alternator also.
tocicar8825
Sep 21, 2021 07:10 AM
svnt442
Jul 17, 2011 04:43 PM
blonzz
Oct 25, 2004 02:19 PM
