Too Warm
Old Jun 28, 2007 | 06:57 PM
beanship's Avatar
Question Too Warm
Not getting any cool air. Topped off the freon, clutch won't kickin, jumped switch at accumulator and clutch kicks in. Still no cool air coming out. When running, low side is showing a negative reading, high side is about 90. Haynes manual indicates that may be an obstruction on the low side. So I don't get ripped off, how much should it cost me to get the system flushed and refilled?
Old Jun 28, 2007 | 07:44 PM
ozoneblue's Avatar
Still may be too low on freon ,what was your static pressure reading? if below 80-90 ,may just need a orfice tube replaced.if your not familar with this system it could be difficult.
Old Jul 10, 2007 | 09:02 AM
beanship's Avatar
Smile Adding Freon seems to have done the trick.
I added more freon (134a) until the clutch would run continously rather than cycling on and off. I may not have given it a full charge but I'm afraid of overcharging it also. My wife is happy as long as it cools in the heat we have been getting. Thanks for the help.
Old Jul 10, 2007 | 12:36 PM
ozoneblue's Avatar
If it works for you it works for me!
Promethean
Apr 18, 2013 03:52 PM
69'442
Sep 23, 2012 12:47 PM
69'442
15
Aug 2, 2012 06:55 PM
erudek
Oct 4, 2010 06:25 PM
rustyold66
Aug 7, 2008 07:52 PM
