98 Bravada auto climate control
Old Sep 6, 2006 | 07:37 PM
cliffg8's Avatar
Just got the car back from being in the shop for 2 weeks. It will only blow hot air no matter what the control is set at. Compressor is running and line is very cold. I can hear one of the air diverter valves move when I move the temp contol. The far right control does change the air output. Just no cold air. Is there a diverter that isn't closing to cut off the hot air? How do I fix it?
Old Sep 11, 2006 | 06:58 PM
atownhockey19's Avatar
maby the **** is broken...
Old Sep 11, 2006 | 07:11 PM
cliffg8's Avatar
No the **** is not broken.
However I did find the problem. The actuator that moves the air mix door from the heat to cool side goes into a mode where it will not move. This can be caused my the door sticking. Under the hood on the housing to the heater/ ac unit there is an area marked. "Cut for service". After removing the area marked there is an access panel with 3 screws. Remove this panel and you will see the air mix door. I manually moved the door from heat to cool a couple times until it didn't feel like it was binding. Do this slowly because the actuator is an electric motor to gear arrangement. GM wants about $120 for the actuator. They are available on ebay for around 35 plus shipping.
Anyway, after moving the door I started the Bravada and selected a mid temp. The mix door moved to a mid way position. I then selected all the way cold and the door moved to block off the heater core. Selecting all the way hot and the door moved to block off the AC side.
If you do have to change the actuator it can be gotten to by opening the glove box all the way. There is a metal loop on the upper left of the opening that prevents the box from swinging all the way out. The loop will swing out to allow the box to open all the way (and dumping its contents on the passenger floor).
You then can look on top of the heat unit and see the actuator. It is on top back by the firewall. It is held in place by 3 screws and has the control wire plug attached. Removig the screws and moving the actuator up will release it from the air mix door. Then just unplug the control wire plug.
I hope this helps someone else.
Old Sep 12, 2006 | 04:52 AM
Oldsguy's Avatar
Past Administrator
Good tech! Thanks
Old Oct 21, 2006 | 08:42 AM
klenard's Avatar
Worked Great
Moved the door a few times......heater works again
Old Sep 8, 2008 | 06:31 PM
MBenton's Avatar
"However I did find the problem. The actuator that moves the air mix door from the heat to cool side goes into a mode where it will not move. This can be caused my the door sticking. Under the hood on the housing to the heater/ ac unit there is an area marked. "Cut for service". After removing the area marked there is an access panel with 3 screws. Remove this panel and you will see the air mix door. I manually moved the door from heat to cool a couple times until it didn't feel like it was binding. Do this slowly because the actuator is an electric motor to gear arrangement. GM wants about $120 for the actuator. They are available on ebay for around 35 plus shipping.
This post worked perfectly... Thank you so much. I live in the southeast and it is Sept 2008 and it is about a million degrees out today and all I could get out of my ac unit today was HEAT!!! I looked up the fix found this post and did exactly what it said.. It worked.. I now have A C again. I disconnected the actuator in the cool position and now I have cool air.. Now I have to figure out how to get the actuator off to replace.. I can get to 2 of the screws but not the one on the underside?? any suggestions?
Thanks for this post it was a life saver and now I am cool.
Old Nov 7, 2008 | 08:04 PM
kirk71's Avatar
my heater blows hot and cold when it wants to, i turn the ***** and nothing changes help please
Old Jun 24, 2009 | 09:54 AM
Boldsmobile's Avatar
When i had my Bravada i had this problem. What normally happens is that a gear in the actuator motor cracks and than wont move the door. I was able to fix it by making a washer ring out of aluminum that held the split gear tight and than epoxied it. It held up until the gear split in another spot and than i just bought another actuator. Please, please please search the web you can find the actuator for about $70. I bought it two years ago and unfortunately lost the web site info. They can be had cheaper than 120.
I removed mine by using one of those "thumb drive wheels" with a socket on it.
Sears has them cheap.
Old Jun 7, 2010 | 06:29 PM
kurtdaniel's Avatar
The exact same thing is happening on my car.. It is intermittent, but incredibly uncomfortable when it occurs..i changed its Bug Shield but still does the same,,what do you think causes this..??
Old Dec 1, 2013 | 03:17 PM
ShadeTreeJack's Avatar
thanks for the posts
I traded for a 98 Bravada recently. Heat is max all the time. Thanks to your posts, I know I have ordered the right part (automatic temp) and will have blended air soon. You also have convinced me that I can get the part replaced. looking at the tight space and squeezing my hand in there, I was saying 'no way!'. I'll get back and let you know how it goes.
98 Bravada
2000 Alero
previously:
68 Cutlass S Convertible
79 Delta 88
81 Delta 88
Last edited by ShadeTreeJack; Dec 1, 2013 at 03:24 PM. Reason: add my Olds ownership
scoutdad57
Bravada
15
Jul 12, 2010 06:50 PM
oldsonharmont
Nov 18, 2009 06:12 AM
mark77301
Nov 11, 2008 10:49 PM
toeppjr
Intrigue
Aug 28, 2007 01:06 PM
skifast
Jun 17, 2006 07:38 AM
