New drum Brake shoes wearing odd
So I have all new drum pads, brake cyl. drums and such on the front for my 69 cutlass. They were doing great but in the past couple of weeks, they seem to be acting a little wonky, nothing to keep me from stopping, but decided to pull off the drum today.
Everything is seated, looks great, but feeling the brake shoes themselves, the back pad feels nice, just like it should, but the front pad is getting worn at the top and bottom but leaving the middle smooth like it should. The wear on the top and the bottom of the one shoe makes me worried, its pretty rough, nothing I am to worried about atm, but what could be causing it to wear in just those two spots? the rear pad of the drum is perfectly fine, and nothing is out of line.
oh, i forgot to mention that I don't have the break booster hooked up, does that change anything on the subject? Brake booster took a dump on me after the last master cyl. i installed, so i just plugged it up and am running manual brakes.
The brake booster is irrelevant to shoe wear. Note that if you have the booster disconnected, the brake force at the pedal will be higher than for manual brakes. The pedal ratio is different for manual and power brakes.
Del70
Brakes/Hydraulic Systems
May 6, 2013 11:47 AM
Aceshigh
Mar 24, 2011 05:43 AM
Rocket Richard
Nov 4, 2010 01:27 PM
1k442
Nov 30, 2009 12:37 PM
