1954 Olds 98 rear drum brakes
On a 1954 98, four door sedan, How do the rear wheel drum brakes come off the rear axle after removing the wheel? then If the power break master cylinder goes dry, what do I do to bring them up to working brakes again. I know brakes, just not this kind of car?? Thank You. dodgerampickup July / 22 / 2012.
I am not familiar with your car, but in that era, the brake drums were held onto the axle with a very large nut that screwed onto the end of the axle. The hub, which is part of the drum has a tapered hole in the center that slides over the end of the axle, and the nut keeps it on. There is a key way in the axle that keeps the drum from spinning on the axle. You need a brake drum puller to remove these drums, a big hammer, and a lot of patience and perseverance to get them off. It is the kind of a job that you will break a sweat even it is 20 degrees below zero.
I forgot to mention when you replace the drum re tighten the shoes till the drum will not rotate then back off 12-14 clicks on the star adjuster till the drum rotates freely, try to do all the wheels the same. Keep the master cylinder reservoir full all the time.....Tedd
Tedd is correct. I would only add that some GM cars of that ear were known to have a spring steel fastener on one of the studs that has to be taken off by screwing it off, before the drum may be removed.
The 1954 olds 98 power brake left rear wheel cylinder leaked out and the power brake master cylinder dipstick at the left lower engine compartment at the steering colume shows nothing. It is dry. On this car you can not see a resivour. Just the dipstick with no markings on it. 1955 and 56 should work for reference.
I was told that those clips were used to keep the drums from vibrating off on the assembly line. Most guys just broke them off the trashed them.
The 1954 olds 98 power brake left rear wheel cylinder leaked out and the power brake master cylinder dipstick at the left lower engine compartment at the steering colume shows nothing. It is dry. On this car you can not see a reservoir. Just the dipstick with no markings on it. 1955 and 56 should work for reference.
What is the capacity of the power brake master cylinder when full? Any yes i can see this is going to be a mess with fluid all over otherwise. You have no idea where the level is at..... Are there no marks at all on the brake fluid dip stick?? Is that right and/or correct?? If it is dry, does the tredal vac power brake system need any repairs?
I fill the master cylinder up till the fluid is about 1/4 inch from the top of the dipstick when it is screwed down. There are no marks on any of the dipsticks from that era also there shouldn't be any problem with the treadle vac unless time has dried out the seals. If this is a recent problem with the wheel cylinder and it worked before it's doubtful that the master will have to be rebuilt. Did you drive this car before the wheel cylinder gave out?
As far as the amount of fluid you will need I would buy at least a quart remember you will be bleeding all the lines and it could take more if you have trouble with a bubble you can't get out. Don't reuse any old fluid it's not a penny saved, it will cost you in the long run.....Tedd
Drove the car last four years ago. and no issues. The left rear wheel cylinder gave out while sitting and I went to use the car and no brakes. I am strongly considering replacing the right rear wheel cylinder too. I do not think the tredal vac or the master cylinder needs to be rebuilt at this point but I will see... I do not reuse brake fluid. Thank You very much for your Help in placing my car back on the road. I am also having to rebuild the carburator due to the both the primary and secondary floats are filled with gas. When I started it, it died because it was flooded with gas. Took off the batwing and there was a pool. I cannot let the cars sit. Have to use them. dodgerampickup
455Olds
Brakes/Hydraulic Systems
December 8th, 2013 08:16 PM
Oldssupreme
May 9th, 2013 08:06 AM
Oldssupreme
January 29th, 2013 07:03 PM
1carsick
23
October 2nd, 2012 05:50 PM
