56 Olds Brake issue
Old May 20, 2011 | 07:55 PM
Dapper 1956's Avatar
56 Olds Brake issue
Took my 56 Oldsmobile Super 88 for a drive and noticed my brakes had a lot of fade. The pedel went to the floor with little to no stopping power. I replaced the wheel cylenders on all four sides along with the shoes and adjusted them. When I took the car out for a road test same issue. I bleed the lines a 2nd time and Had the same issue pedal went to the floor and car did not want to stop. Anyone know whats going on? THe oldsmobile had a power brake system like buick and cadillac.
Old May 20, 2011 | 11:36 PM
oldsmobum's Avatar
Sounds like your master cylinder is dead. Usually the seal is dead and cannot pressurize the brake system like it should. Unfortunately I haven't been able to find a rebuild kit for it or a master cylinder only available... They only seem to come with the booster rebuilt which might not be a bad thing anyways. Now is a good time to contemplate retrofitting a dual master cylinder on the firewall or even adding disc brakes
1yesfan
Aug 4, 2015 06:40 PM
Dead Reckon
Jul 14, 2014 02:35 PM
stratoblues
Brakes/Hydraulic Systems
Jul 30, 2012 02:46 AM
Dapper 1956
May 5, 2011 01:43 PM
54olds
Jun 25, 2008 12:46 AM
