Thanks, John for the correct parts. Mike at Brakebooster did a great job.
FYI Mike recommended Synthetic Dot 4, Castrol brand in particular. Said Dot 5 would void the warranty. Dot 4 Synthetic won't eat the old-skool rubber. He also mentioned when bench bleeding don't go into the master more than an inch or so with the piston. In other words, don't bottom it out.
