Brake fluid
Old May 17, 2023 | 07:45 AM
dennis_30281's Avatar
Brake fluid
Getting ready to add the brake fluid to my 1962 Starfire brake system. I had the original booster ohauled and replaced the single master cylinder with a dual.
I understand that dot 3 should be used, but since dot 5.1 has the same base as dot 3 and over a 100 degree higher boiling, can I use 5.1.
oh yes, drums in the fear, discs in front.
Old May 17, 2023 | 08:02 AM
Because my car sits for up to five months in the winter, I use DOT-5 silicone brake fluid in my Olds, preferring to sacrifice a little ultimate performance for practicality of storage due to its non-hygroscopic nature.
Old May 17, 2023 | 08:09 AM
DOT 5.1 is perfectly fine. I would recommend it.
stuhes
Brakes/Hydraulic Systems
Jun 2, 2018 03:53 PM
rodan
Mar 29, 2016 04:33 PM
D. Yaros
21
Sep 8, 2014 08:20 PM
Sampson
18
Apr 9, 2014 03:32 PM
Bunser
Sep 29, 2009 05:20 AM
