Brake booster
Old Oct 21, 2020 | 03:55 PM
griffey57's Avatar
Brake booster
I just had my brake booster rebuilt on my 57 olds and bled the system and bench bled the booster and adjusted the brakes. When I first step on the pedal it goes to the floor and then after 1 pump it is perfect, any ideas why it is doing that?
Old Oct 21, 2020 | 07:50 PM
Air in the system and brakes may need adjustment.
Old Oct 24, 2020 | 07:12 PM
griffey57's Avatar
Bked the system 3 times. No air bubbles came out and already adjusted brakes
Old Jan 25, 2021 | 01:23 PM
laidenz's Avatar
No air or vapor can escape from a closed system. Even if you can get the bubbles to dissolve in the fluid as soon as the pressure is released and the brakes heat up the fluid, those air or vapor bubbles will be right back again.
rogiestone
Brakes/Hydraulic Systems
Dec 7, 2020 02:40 PM
griffey57
Oct 4, 2020 06:58 AM
brandon reynolds
Aug 27, 2020 08:59 AM
70sgeek
Feb 11, 2019 01:39 PM
cobalt
Mar 2, 2014 09:22 PM
