Junkyard Hydroboost
Old Sep 15, 2020 | 05:59 PM
Jhucks03's Avatar
Junkyard Hydroboost
Finished up installing a junkyard Hydroboost setup off of an Astro van onto my 71 Cutlass. Replaced proportioning valve and all lines.
Having a problem with the pedal not fully returning when engine is running. It returns as expected when engine is off. Has GREAT stopping power and fluid at all 4 bleeders. I can pull up on pedal and it stays.
Any ideas?
Old Sep 15, 2020 | 09:01 PM
rocketraider's Avatar
Oldsdruid
Have you completely bled the power steering/HB hydraulic system? You have the hydraulic pressure and return lines routed correctly?
Which PS pump did you use?
Old Sep 16, 2020 | 06:27 AM
Jhucks03's Avatar
Factory Cutlass pump. I copied the hose routing from the Astro.
And I assume it’s bled as fluid level stabilized after turning lock to lock a few times.
Old Sep 16, 2020 | 06:30 AM
oddball's Avatar
Did you tear down the booster? Junkyard stuff around here is usually full of water and crud. You can get rebuild kits from Pirate Jack, and the basic steps are really easy.
Old Sep 16, 2020 | 11:07 AM
Jhucks03's Avatar
I have not rebuilt it.
I noticed at lunch today that the pedal will fully return itself after the car is shutoff (from last application not allowing full return).
Old Sep 25, 2020 | 01:49 PM
Jhucks03's Avatar
Remedied the problem. I had added a small cooler inline on the return side. My thinking was it wouldn’t hurt seeing as how I was gonna be using the pump harder (I thought).
Anyway, I took the cooler out of the system. And voila - pedal returns as normal. Exceptional braking power. Well worth the effort.
Old Sep 25, 2020 | 04:06 PM
RetroRanger's Avatar
72 Olds CS
good deal
thks for posting back
Old Sep 25, 2020 | 04:28 PM
Oldsdruid
Good info. Tks for passing it along.
Old Sep 25, 2020 | 06:40 PM
cdrod's Avatar
Rodney
Got any pics of the install?
Old Sep 26, 2020 | 06:28 AM
Jhucks03's Avatar
I’ll try to get some today. Just keep in mind this ain’t no showcar. It’s a driver. I wouldn’t have one if I couldn’t drive it and romp on it from time to time.
Old Sep 26, 2020 | 12:56 PM
yeahbuddy's Avatar
I was almost going to go this route and someone talked me out of it. I ended up going 4 disc manual instead and I love it so far.
Did you make your own AN braided lines or did you buy premade rubbed lines (from a Cadillac I believe)?
Eaton3122
Brakes/Hydraulic Systems
Apr 27, 2020 09:16 PM
abrasv
Sep 14, 2018 04:25 AM
Mark71
23
Jul 25, 2016 12:45 PM
dmruschell
Jun 11, 2016 03:10 PM
Rocketbrian
Nov 30, 2015 04:02 PM
