proportioning valve
proportioning valve
hi al ,wondering ,can I use a universal one that edlebrook has listed .for a 65 starefire? have changed wheel cylinders power booster and master cylinder, a few times feels like im stepping on a brick, just slows down alittle , thanks for ant help/ will
proportioning valve
down on the frame below the booster there is a brass type union , which I thought was the valve, well I guess that ends that ray of hope.thank you for the info. will
That is simply a distribution block. There is no valve inside of it. What master, booster, and wheel cylinders? Stock replacement or something else? What is the vacuum level at the booster?
proportioning valve
thanks , all stock, vacuum is 17 to 18 lbs, sometimes brackes will work good if put neutral when im coming to a stop.2 new masters and 2 new boosters, thanks again , will
Obviously if the brakes don't work consistently, you have a problem. If the pedal is hard, that's a booster problem. Could be that the pushrod isn't adjusted properly, or it could be that the air admittance valve sticks sometimes.
I'm hedging towards push rod adjustment. It isn't a necessarily a case of the wrong hole, even w/ the correct hole, the push rod between the MC and the brake booster needs correct travel distance (adjustment).
68442Convertible
Brakes/Hydraulic Systems
Jul 24, 2019 11:34 AM
