1956 Olds vacuum check valve replacement
Have a 1956 S-88 that has a leaking vacuum check valve that connects between carb base, vacuum reservoir, and power brake booster. Fusick doesn't have a replacement and said that I'd have to adapt a check valve of some sort to replace it. Has anyone done this? If so, would you be willing to share what you did?
Thanks,
Keith
Thanks,
Keith
Is this the same?
https://www.ebay.com/itm/1955-1956-1...QAAOSwlaxWOKez
No, it was more like this one except mine is all white.
https://www.ebay.com/p/Power-Brake-B...d=132408559717
