72 front drums
Old April 3rd, 2017, 09:57 AM
bones's Avatar
72 front drums
Good morning
I cant seem to get on to one of the wheel cyl. Mounting bolts because some of the linckage is in the way. Anyone else run into this problem? Do i need to unbolt they backing plate and the big nut just abouve the wheel cyl?
bones is offline
Old April 3rd, 2017, 10:01 AM
VI Cutty's Avatar
I did it without unbolting anything else, but it was a real PITA to be sure. I wound up threading the brakeline in before the cylinder bolts just to get enough wiggle room to make it happen. Had to crank the wheel hard over too.
I'm interested to see if there is a better way too!
VI Cutty is offline
Old April 3rd, 2017, 10:59 AM
I always turn the wheel all the way to the right or left depending on which side I'm working with. Sometimes its easier to install the problematic bolt first with the wheel cylinder pushed out and then tighten and draw it into the slot it fits in.
oldcutlass is offline
Old April 3rd, 2017, 11:32 AM
bones's Avatar
The problem is getting the old one off. I have the wheel cranked over but i cant get the socket or wrench to fit over the head because this piece prevents a snug fit. Im afraid im gonna strip it. Ill try and take pic.
bones is offline
Old April 13th, 2017, 05:05 PM
bones's Avatar
Finally got it off. Had to heat and bend a wrench to the right angle.
Seperate question....are the front shoes 9.5 by 2.5 or 9.5 by 2?
Im at work and want to order so i cant measure right now. Lol
bones is offline
Old April 13th, 2017, 05:34 PM
Full-time Taxpayer
Qwik71442's Avatar
Front are 2.5 wide
Qwik71442 is online now
Old April 13th, 2017, 05:39 PM
bones's Avatar
Great thanks.
bones is offline
phil7395
Ninety-Eight
December 9th, 2011 02:16 PM
coppercutlass
Brakes/Hydraulic Systems
18
December 6th, 2011 01:00 PM
my69olz
July 2nd, 2009 08:27 AM
65 starfire
February 4th, 2008 04:33 PM
JoshF85
July 28th, 2005 05:15 PM
Quick Reply: 72 front drums
