Vacuum pump install results
Old Jul 22, 2023 | 08:03 AM
oldsrush's Avatar
Gearhead
My car only has 14-15" vacuum and the power disc brakes were not stopping the car like it should. I installed a vacuum pump supplied by MasterPowerBrakes. Car now has 26"+ of vacuum and brakes work like a new car. Pump is quiet enough not to hear above sound of running engine and small enough to mount in cavity behind battery. Now I can run a bigger cam and would recommend to anyone.
Old Jul 22, 2023 | 08:06 AM
In case "others" in particular new members might not be following along this is on your 1967 Oldsmobile 442 Tripower w/455 auto I assume?
Old Jul 22, 2023 | 08:49 AM
oldsrush's Avatar
Gearhead
That is correct.
Old Jul 22, 2023 | 09:32 AM
70sgeek's Avatar
'72 Cutlass ragtop
Carry extra fuses with you for it - a blown fuse may leave you essentially without brakes, without warning.
Happened to me on a Bandit brake pump that I tried out a few years back - great piece, quiet and worked very well for a few weeks.
One day approaching a stop sign, found I had just about no brakes and barely able to stop before blowing into the intersection. I had fuses on hand and that corrected the problem for the ride home, at which point I removed the unit.
Old Jul 22, 2023 | 09:37 AM
gs72's Avatar
72Cutlass S
Does the pump run constantly or on demand?
Old Jul 22, 2023 | 09:40 AM
You will still have brakes. You just won't have power assist. Power brakes work when the engine isn't running.
Old Jul 22, 2023 | 09:57 AM
oldsrush's Avatar
Gearhead
Runs on demand
brotherGood
Jul 5, 2023 10:46 AM
New2Olds57
Oct 16, 2022 01:29 PM
quentinnw2
Oct 25, 2013 09:26 AM
chasman414
Apr 18, 2013 02:23 PM
zodiacblueS
Brakes/Hydraulic Systems
Oct 4, 2012 06:22 AM
