Top cylinder problem
Old Jul 16, 2009 | 05:45 PM
tarheeldoc's Avatar
I just reinstalled the convertible top frame on my 69 Cutlass. While the car was apart, I had the top cylinders checked for leaks and was told that they were good. Last night,I went through the procedure in the manual for bleeding out the air and everything looked good and was dry through several up and down cycles. Tonight, I went out to the garage and there is a puddle of hydraulic fluid under one of the cylinders. On putting the frame up, I see it is leaking from the top around the rod. Do I need a new cylinder, or is there possibly another (cheaper) solution?
Old Jul 17, 2009 | 04:26 AM
scrappie's Avatar
Sounds like the seal may have dried out while sitting? or maybe it was dropped and there is a hair line crack or something. I find these cylinders very fragile. The area I find most prone to problems is the nylon threads on the top part of the cylinder. They can be stripped with the slightest bit of over torque. Once they are stripped they usually continue to leak. There was a post on this subject and someone actually took the time and had the expertise to rebuild. I don't. In your case you might have to fork up the $ for a new one or nice used one if you can find.
Old Jul 17, 2009 | 06:08 AM
tarheeldoc's Avatar
Thanks for the info. I didn't realize they were that fragile, and do seem to recall knocking one off the bench a few weeks back. I'll keep my fingers crossed that the other one keeps working and stays leak-free.
Ken
revrory12
Oct 26, 2021 08:54 AM
smit4425
Dec 30, 2012 03:20 PM
dougm
Aug 15, 2011 05:05 AM
KevinBN7
Jul 17, 2011 01:02 PM
veltboy618
Brakes/Hydraulic Systems
Jul 14, 2011 07:10 PM
