setting up the hydrolic's
Old Aug 3, 2007 | 08:45 PM
dynamic88's Avatar
does anyone know how you go about setting up the hydrolic system on a convertible? i have a 65 olds dynamic 88. i tried tonight to get the hydrolics all set up and purged but im not sure i was doing it right. there seem to be alot of air going through the lines. i filled the motor up as full has i could get it, then i put a tub into the fill hole on the motor and dropped the other end into a gal jug of hydroilic oil, then tried raising the top while sucking in oil at the same time. does this sound right or am i doing it wrong? thanks chris
stlbluesbrother
Nov 23, 2009 08:56 AM
Red Delta
Oct 25, 2009 05:03 AM
Olds64
Aug 25, 2009 09:22 AM
1973olds98
Aug 24, 2009 07:05 AM
dynamic88
Brakes/Hydraulic Systems
Aug 2, 2007 08:52 PM
