rubbing brakes
Old Aug 22, 2012 | 04:48 PM
deltaskelta's Avatar
rubbing brakes
I have a 85 delta 88 that sat for a while now I have it running but while rolling I can hear the brakes rubbing can some one tell me what's causing the problem and the solution
Old Aug 22, 2012 | 08:26 PM
Lady72nRob71's Avatar
Can you tell if it is the front or rear? Have you jacked up the car to see which ones drag?
Have you done a visual inspection on them recently?
Can you see is any particulat set of pads / shoes are worn?
There is a big variety of issues that can cause this, we just need to do some logical troubleshooting.
Old Aug 22, 2012 | 08:30 PM
Rickman48's Avatar
Usually rust on the drums or rotors from sitting - it'll go away.
How long was your Delta sitting?
Are you sure you're not hearing the audible brake wear tab? When the disc brakes wear down to a certain point, they have a metal tab that rubs on the rotor causing a nasty scraping sound. Pull your front wheel and look at your brake pads to see if this is what's happening.
Old Aug 22, 2012 | 09:13 PM
It's the front set and I have pulled the wheels and looked. The rotors look surprisingly in good condition and the pads look to be in decent shape idea say about half life and close to even ware now since I've done the overhaul I haven't realy driven the car more than 15 or 20 miles. The fluid looked to be ok but like I said it sat for proly a year or so not sure exactly. Brake fluid brake down after long periods of time. If so how do I flush the brake system I know how to bleed em but that's about it.
Old Aug 23, 2012 | 06:52 AM
Do you get a vibration when you apply the brakes, like a shimmy? Pads on disc brakes generally run with a nats *** of clearance. You might pull the wheels and lubricate the area that the caliper rides on the mount if everything else is ok.
Old Aug 23, 2012 | 07:07 AM
You could always slowly crank each caliper piston all the way in with a C-clamp to be sure they move freely, then bleed the brakes until the fluid runs clear, then try 'em again.
If a caliper begins to leak after cycling the piston all the way back and forth, it was no good anyway.
Old Aug 23, 2012 | 07:15 AM
Ok will do. And get back to you thanks for the sugestions
tmatador
Wheels and Tires
Oct 7, 2011 10:52 AM
crjeeper
Apr 13, 2011 07:45 AM
suppressivefire
Nov 24, 2009 05:48 AM
import extermination
May 17, 2009 11:07 AM
New'n72
Oct 3, 2007 02:36 AM
