Rear disc from 85 Eldorado to 85 cutlass???
I been wanting to do a rear disc swap on my cutlass & I found a 1985 Cadillac Eldorado with rear disc brakes at a local salvage yard so i can probably get everything I need for cheap. Both rotors which are the same bolt pattern & calipers are there & the proportioning valve but I dont know if I need that or not. I have read about people using these parts to do a rear disc swap but never seen pics after it was finished or heard any feedback after the conversion was complete. Is this a pretty good kit to put on my 7.5" rear end & what brackets will need to mount everything?
Don't know if anyone makes a conversion bracket for your car. but these are used with the scarebird rear break conversion bracket because the e-brake is built into the caliper. Go hear http://www.scarebird.com/ and see if your car is listed.
DeadBang1968
February 26th, 2011 11:21 AM
DeadBang1968
January 19th, 2011 07:35 AM
jaunty75
December 16th, 2010 06:32 PM
