Proportioning valve location question
Old Dec 30, 2023 | 06:08 AM
JesseOldsGuy's Avatar
As you can see, the proportioning valve doesn’t look like it will fit in the place where the bracket wants it to. I cannot move to the other side. As far as I can see, I need to modify the bracket so as to put the valve under the master cylinder. Does anyone have any ideas?
Old Dec 30, 2023 | 09:52 AM
oddball's Avatar
Stock Olds location is down on the side of the frame rail and stock-style replacement lines will run down to there. Even then it's common to have to move it to the top of the frame to clear headers.
Underneath the master is the next most common aftermarket mounting point. You can probably find a bracket if you don't want to make/modify one. The generic kits take a more Chevy-centric approach with the valve up high.
Old Dec 30, 2023 | 10:43 AM
72455's Avatar
1972 U code Supreme
YMM would help us point you in the right direction, but I ordered the bracket for my '72 Supreme from ILT. Worked like a champ.
Old Dec 30, 2023 | 02:14 PM
nicks1966's Avatar
This is how I have it mounted on my 66
Old Dec 31, 2023 | 07:40 AM
The chassis mount spot was where I found the original distribution box. When I tried to locate the proportioning valve there, the starter cable was in the way. So, I would have to fabricate something to move the cable out of the way. I thought it would be easier to move the proportioning valve. Not sure about that now.
Last edited by JesseOldsGuy; Dec 31, 2023 at 07:41 AM. Reason: Clarify my statement
Old Dec 31, 2023 | 07:43 AM
I saw the bracket that holds the valve on its side under the valve last night. Thank you for the photos showing how it would work. I think that might be the way to go. The downside is that I have several pre-bent lines which might not work.
Old Jan 1, 2024 | 01:38 AM
The lesson-learned here is never expect aftermarket parts to fit correctly, unfortunately.
Old Jan 11, 2024 | 07:10 AM
The parts have arrived, now onto the brake lines.
Old Jan 16, 2024 | 04:21 PM
The front brake lines are installed. You can see that this is the first time I have done this.
glent
Brakes/Hydraulic Systems
Dec 8, 2021 01:22 PM
dalilama
Feb 24, 2017 07:37 AM
sicky olds
Mar 3, 2014 06:52 AM
1978 Oldsmobile Omega
Feb 21, 2014 01:03 PM
OLDSmobility
Apr 29, 2011 08:15 AM
