No brake pedal up and solid
Old Apr 10, 2024 | 07:02 PM
JAAMMS13's Avatar
1971 cutlass 350
all parts are new I have no brake pedal won't go down rock hard. Was originally 4 wheel manual drum I am converting to 4 wheel power drum. Everything is together so I started process of elimination. I rebled the master cylinder when I hooked up just the front brake lines to the master cylinder I would get a brake pedal. I then proceeded to hook up the rear brake line to the master cylinder it became rock hard. I then went to the proportioning/ distribution valve and checked for fluid and got fluid. Then I checked at all the traders for fluid and got fluid. When I went to bleed brakes again got strong fluid at rears but pedal froze again. I think it mite be the proportioning/ distribution block. What valve should I use and is this possibly the problem. Thanks in advance
Old Apr 10, 2024 | 07:45 PM
jmcghee's Avatar
Sounds to me like your push rod is too long. Make sure it is in the lower hole on the brake pedal. Sorry too tired to explain better now.
Old Apr 11, 2024 | 05:22 AM
JAAMMS13's Avatar
Checked rod already and when bleeding pedal will go to floor
Old Apr 11, 2024 | 06:21 AM
mpowell's Avatar
Assuming master is bled correctly and all 4 wheel cylinders bled correctly you can expect a pretty stiff pedal with drums x4. Mine has very little downward motion without boost to help. Have you test driven it after allowing vacuum to build up in new booster? Should soften the pedal a bit and give more downward allowance.
Old Apr 11, 2024 | 07:54 AM
JAAMMS13's Avatar
what proportioning / distribution valve did you use
Old Apr 11, 2024 | 09:54 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Are the soft lines new?
Verified the booster is holding a vacuum?
Is the oneway valve vacuum on the booster working? What are you using as the vacuum source? The OEM line to the carb TB?
OEM booster or afterchina?
Old Apr 11, 2024 | 10:53 AM
When you press on the pedal, is there any motion at all? Does fluid flow out of the bleeder screws?
MPSax
Brakes/Hydraulic Systems
Jul 29, 2023 05:34 PM
jpilk99
23
Jul 9, 2023 07:36 AM
Big Dawg
20
Oct 19, 2014 08:02 PM
elisekasten
May 18, 2014 11:56 PM
dynamic88
Jul 28, 2007 08:04 PM
