No brake fluid coming out of master cylinder, 69 Toronado
Old May 8, 2022 | 04:26 PM
goodeye69's Avatar
Still going on the brakes... I have a master cylinder, power booster, and distribution block restored by White Post. Assembled it all onto the car. Bled the 4 wheels, and did get fluid for a while (in hindsight, feels like I just drained the lines). Did a "bench bleed" while mounted in the car, and got one pedal pump's worth of fluid out of the MC ports, then no more. Attached a pressure pump to the MC, pumped it to steady pressure 5-8 psi and holding. Nothing from the wheels, so I unscrewed the MC output ports, and nothing comes out. I tried pumping the pedal too, nothing.
Am I missing something, to get the fluid to "go"?
Also, the pedal is making a mechanical thunk about half way down the travel, that doesn't feel right.
Any suggestions?
Thanks.
Old May 8, 2022 | 04:38 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Did you bench bleed the master cylinder in a level position in a vise?
Old May 8, 2022 | 04:59 PM
goodeye69's Avatar
No, I already mounted it before I learned that (I kept asking friends how do you bench bleed when there are no bleeder screws, then finally turned to youtube).
So I tried to "bench bleed" it in place. That's when I got a little out of it from pumping the pedal, but then no more. The syringe approach didn't work at all.
This is a 4-drum car, with just two output ports on the MC, by the way.
I can try it. If the MC is bad, it'll have to come off anyway.
Does removing it from the car make a difference, with nothing coming out at all? This feels more "blocked" than just air bubbles (but I don't know MC operating details). Shouldn't the pressure pump have pushed it through?
Old May 8, 2022 | 05:25 PM
goodeye69's Avatar
Bench bleeding it now - might as well to be sure. Those 2 bolts are easier than anything else going on!
Old May 8, 2022 | 05:44 PM
goodeye69's Avatar
ok, pulling it at least I can see more of what's going on. Pushing on the piston was very hard. It initially only moved 1/8", then I pushed harder, and now it travels about 1/2". As before, one "pump" of fluid came out when I got it to move that 1/2", then no more. I push it in and out that 1/2", and no more fluid is moving. How far should it travel, and how hard do I need to push?
Old May 8, 2022 | 08:30 PM
Sugar Bear's Avatar
How far in? I'm not sure, but more than 1/2". While bench bleeding have you set up a return hose/tube from the ports back to the reservoir with the end of the return under brake fluid so it doesn't suck air back in?
Old May 8, 2022 | 08:40 PM
redoldsman's Avatar
Based on how hard it is to push in and not further than it travels I am thinking you have a bad master cylinder. I might be wrong but that is my guess.
Old May 8, 2022 | 08:56 PM
goodeye69's Avatar
Yes, I did the adapter nozzles with tubes back into the reservoir, then a screwdriver to push the piston. This is all swirling around that something seems mechanically wrong - this isn't air in the system. It was just restored, so I'll give White Post a call tomorrow, see how to proceed.
dalilama
Brakes/Hydraulic Systems
16
Jul 10, 2017 10:15 AM
TheBigBlueBoat
Jan 13, 2016 06:02 AM
Big Dawg
20
Oct 19, 2014 08:02 PM
1973nomega
20
Jul 24, 2014 08:14 AM
kndllmtt
Oct 1, 2012 06:09 PM
