New brake bleeding tool
Old Jun 6, 2015 | 09:12 AM
This is one of those "why didn't I think of that" tools.
One frequent problem when bleeding brakes on dual circuit systems is that the piston in the differential pressure switch can get forced all the way to one side or the other and block that brake circuit from flowing. This problem is compounded if you have an original cast iron combo valve that might have rust in it, as the piston gets stuck.
PerformanceOnline.com has just come out with a clever tool that simply screws into the distribution block or combo valve and locks the differential pressure switch piston in the center position while bleeding the brakes. You simply unscrew the plastic switch body, temporarily replace it with the tool, and bleed the brakes. No, brake fluid will not leak out, as the space around the piston is dry and sealed by o-rings. If you do get fluid, the valve is bad anyway.
Just remember to put the switch back in when you're done. $8 online.
https://www.performanceonline.com/Co...ve-Bleed-Tool/
Old Jun 6, 2015 | 09:27 AM
Whoa. Dude. That's a smart little tool.
Old Jun 6, 2015 | 06:38 PM
Yellowstatue's Avatar
I like it! I like it!
Old Jun 6, 2015 | 06:53 PM
Octania's Avatar
Evidently they never learned that "cutaway" is one word.
Definition #3
http://dictionary.reference.com/browse/cutaway?s=t
great idea for a tool, and modestly priced
Old Aug 19, 2015 | 07:46 PM
crimsoncolby's Avatar
I used this tool a couple summers ago and it worked like a charm. Love it when something this inexpensive can save so much time and frustration.
Old Jun 27, 2020 | 11:46 AM
Originally Posted by Orlando 1
When removing make sure the pedal is 1/2 depressed so the master valves close and you don't reintroduce air into the line.
There is no brake fluid behind the differential pressure switch. If there IS any fluid, the seals in the distribution block are bad.
Old Jun 27, 2020 | 03:48 PM
While I thought the tool is cool when you first posted this and have recommended it or similar since for the newbies. I still in all my 40+ years of doing brakes have never needed it to bleed brakes and I still do it the old fashioned way with a my pretty helper to pump the pedal.
Old Jun 27, 2020 | 05:11 PM
I'm trying to determine how a five year old post is resurrected with a quote by someone (Orlando 1) who doesn't even have a post w/in the thread. I think I got too much sun today.
Old Jun 27, 2020 | 07:33 PM
Orlando 1's Avatar
O'smobile
I was stupid and removed the stupidity.
Old Jun 28, 2020 | 05:39 AM
I...removed...
Pewter442
Brakes/Hydraulic Systems
41
Mar 14, 2015 07:02 PM
PhilGGG
Dec 18, 2013 07:06 PM
Deputy442
Sep 5, 2008 05:15 PM
Bluevista
May 21, 2008 10:20 AM
projectheaven
May 15, 2008 01:11 PM
