New Booster/Master
Old Sep 28, 2024 | 05:52 PM
72Vert442's Avatar
New Booster/Master
I installed a new brake booster and cylinder in my 72 convertible. Bleed the brakes and got a firm solid brake pedal. When the engine is running the brake has no smooth return when braking on and off. Stopping is great but the pedal feels weird. When I hit the brake approaching a stop it brakes well but the pedal sort of stays down if I lift. It does eventually push back out or under throttle but it doesnt feel right. Turn the motor off and its very firm. Any ideas?
Old Sep 28, 2024 | 06:59 PM
Sounds like you still have air in the lines. Did you bench bleed the MC first? Is the booster pin correct for the MC actuator?
Old Sep 28, 2024 | 07:59 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Who rebuilt the components?
Does the booster hold vacuum?
Old Sep 29, 2024 | 01:52 AM
72Vert442's Avatar
I bought the booster and master from Fucisks. They were for my model according to the website. The parts looked the same as what I took out.
f I still have air, I would get a solid firm pedal with no vacuum but under vacuum would get what I am experiencing?
Old Sep 29, 2024 | 05:40 AM
You will have a solid pedal with no vacuum.
piperman60
Jun 24, 2021 01:19 PM
Allan R
Apr 30, 2021 03:07 PM
70sgeek
Brakes/Hydraulic Systems
Feb 11, 2019 01:39 PM
jpatfarrell
Dec 6, 2018 01:09 PM
car_designer
Aug 11, 2016 10:21 PM
