Need brake help
Need brake help
Hi Joe, quick question. I got the car finished and the brakes work but not like they should. I bled them very good with my vacuum pump after installing that proportioning valve. I had the shop I took the car to for the alignment (I completely rebuilt the suspension and steering) and had them look at the brake issue.
They told me that there are now two proportioning valves on the car including the one I installed after the disc conversion. The only other 'valves' I saw in the stock brake lines where the blocks that take the brake lines from one to two to go to each corner.
Do you happen to know if there is a factory proportioning valve on the original all drum brakes?
I am going to pick the Cutty up now and plan to have them show me exactly what they are talking about but thought I'd ask here as well.
Thanks in advance!
Thanks in advance!
Hi Ralph, I really don't have anything to get pics of other than the proportioning valve I installed (I posted a pic of it not installed earlier in this thread.)
The only things I saw on the car from factory were the two distribution blocks, and I know those aren't proportioning valves. If I can get a pic of what the shop is talking about then I will post that. Was there something more specific you'd like to see?
Thanks guys!
Thanks guys!
Thanks in advance!
Thanks in advance!
If you have the new brass combo valve as shown above in Post #21, that's the only thing that should be in the system. It replaces the old distribution block used with the drum brakes, however that distribution block is not a "proportioning valve". Any shop that thinks it is has no clue about GM brakes and should not be touching your car.
Thanks Joe, that's exactly what I thought, even the shop manual supports that. It was Big O and it just went in for an alignment and I asked them to give the brakes a once over.
I have a very low pedal, brakes grab well 1/2 way down but if I apply more pedal, I then go to the floor with brake fade. Either way it sounds like I need to take that front distribution block out completely. I had one guy (who builds a lot of cars) advise me that it was not necessary to run two dedicated lines from the front calipers because the distribution block was in place. Sounded logical, so I capped one side on the P valve and ran the factory single line from the dist. block to the other port on the P valve. Apparently, this was bad advice?
I really appreciate the help!
CUTLASS FREAK
Brakes/Hydraulic Systems
Sep 17, 2007 08:57 AM
CUTLASS FREAK
Drivetrain/Differentials
May 14, 2007 08:05 AM
