Line and fitting sizes
Hi all.
Im doing a LS brake upgrade on my 72 Cutlass.
I thought i had everything covered but when i was starting on the lines i discovered that the main brakeline from the distribution block to the Axel hose is a bigger line.. lol.. well i should have looked before, but...
Since the lines are in good shape and im using a adjustable wilwood proportioning valve I want to use an adapter from the normal 3/16 line to the 1/4 (?) line and roule out the frame mounted distribution block near the manifold.
The question is what type of adapter will i need?? I have no idea of the fitting size on the bigger line.
Thanks!
Thanks!
Hi all.
Thanks!
Thanks!
http://www.speedwaymotors.com/IFM-to...ters,6458.html
