Hurst roll control install
Old May 14, 2015 | 08:36 PM
scooter123's Avatar
Hi guys I just picked up a hurst roll control kit and the line kit!!!!
So my car is a 71 delta 88 and it has the brake line junction block thing with I believe the rear brake line comes off the bottom that heads to the rear of the car.......so is it so easy as to disconnecting that rear line and running a new line from the junction block to the in-side which i think is marked with a " M" of the hurst roll control and then a line out of the hurst roll control to the existing rear brake line with a coupling????
Thanks for any help!!!!
Old May 18, 2015 | 02:48 PM
70vert's Avatar
Uhhhh you want to put it in the lines for the front unless you want to lock up the rears to do rockfords?
Old May 18, 2015 | 04:46 PM
scooter123's Avatar
Chose not to try this on my own.... Going to take it to a shop and have it done...... If I ever install it at all!!
Thanks!!
Old Jun 17, 2015 | 08:36 PM
scooter123's Avatar
Well I decided to do it on my own... The line lock is installed and I also installed a new master cylinder while I was in there... The old one had a leak.
Old Jun 18, 2015 | 06:33 AM
And...? Does it roast the tires now?
Old Jun 18, 2015 | 10:00 AM
Octania's Avatar
That seems like a bad idea...
I take it you mean James Rockford-esque instant 180 degree spin turn?
Old Jun 18, 2015 | 09:15 PM
scooter123's Avatar
Yes it will burn now.... Lol..... Might throw on my old tires and rims on the weekend and give it a go...... The Mickey thompsons are too expensive to burn off
Old Dec 22, 2015 | 07:28 AM
76olds's Avatar
Hookers under Hood
Scooter123, would it be possible to post a couple of pics of your install? I would like to purchase the Hurst Roll Control unit along with the line kit for my 76.
Not sure if I would need to purchase a distribution block to install at the master as well.
Also I'm thinking of purchasing the rebuild kit just to have it on hand in case.
If others have done the install I would like to hear from you as well.
Eric
davebw31
Jul 14, 2013 04:52 PM
Deputy442
Sep 11, 2008 11:00 AM
iuhoops83
Aug 12, 2008 09:08 PM
docjcwatson
Jan 10, 2007 02:46 PM
