How to Remove Wheel Stud? - 70 Cutlass
Old Sep 26, 2009 | 10:08 AM
stlbluesbrother's Avatar
Question How to Remove Wheel Stud? - 70 Cutlass
Hi.
I have a couple of studs to replace on my rear wheels (drums). Should I be able to bang these back thru with a hammer? I've already tried a few wacks without success.
And if necessary, how do I pull off the flange the bolts are running thru? Thanks.
Old Sep 26, 2009 | 10:36 AM
Nilsson's Avatar
drill them out, cut off flush and start with smaller bit and work your way up. Drill until there is nothing but a thin wall left of the stud and then
knock them out. Don't drill all the way through you want to have support to bang on with a drift that will fit inside the hollowed out stud. It will take no effort at all to knock out at this point. No chance of damaging or bending anything
Old Sep 26, 2009 | 10:38 AM
I finally got them; took some muscle power to hammer them thru. And, I made sure not to damage the brake parts.
Next step is "pulling" the new studs thru once the knurl edges are lined up. First one looked good and straight.
Old Sep 26, 2009 | 12:07 PM
svnt442's Avatar
An open nut and some flat wahers work wonders for seating new studs.
Old Sep 26, 2009 | 12:35 PM
You hammered the studs while on the axle flange?
Probably not the best method. You've run the risk of bending the axle flange and/or damaging the wheel bearing, unfortunately. At a minimum, get a dial indicator and verify that the flange isn't bent. For future reference, the correct way to change rear studs is to either pull the axle shaft and use a press or use a C-clamp with a socket on the backside to push the stud out. There is a Kent-Moore tool that does exactly this.
Old Sep 26, 2009 | 06:30 PM
svnt442's Avatar
Joe you just spit out some of the most common sense things. Man that would never have dawned on me, but it makes perfect sense.
Old Sep 26, 2009 | 07:45 PM
The muscle power I mentioned was a bit of an exaggeration, but Joe's advice is well received. Fortunately, no damage was made to the axle flange as the drum fit perfectly over the studs and flush with the flange.
My collection of tools is definitely going to expand the more I learn (in advance) and absorb from this forum. A torque wrench is at the top of the list.
EightballZ
Mar 24, 2014 05:03 PM
lshlsh2
Wheels and Tires
Jun 19, 2012 06:26 AM
KRICHEN922
Jul 1, 2010 09:17 AM
stlbluesbrother
Drivetrain/Differentials
Sep 24, 2009 04:50 PM
DAN76
Oct 10, 2008 07:17 AM
