Help please! Brake booster issue
Need some more help please, I just installed a 8 in brake booster with my original mounting bracket and it looks 100% off, it looks way to high in the front. It’s at a crazy angle! Is this normal and if not how do I fix it??
I don’t think my hood will even close
thank you
thank you
I thought those aftermarket boosters came with their own choice of brackets - either upward angled or a straight bracket option - maybe check with the company who made the booster? Some of the companies who offer these booster kits are MP Brakes (Master Power Brakes) and SSB (Stainless Steel Brakes). Possibly their angled brackets are less steeply graded due to the greater depth of the 8" booster over the stock Delco?
If that's a dual 8" booster and a stock 1-1/8" master cylinder, your braking force will be about 10% less than a stock disc brake system. If it's a single diaphragm booster your braking force will be about 30% less. Both of my calculations assume using the stock power brake hole in the brake pedal arm. You could drill a new hole in the pedal arm midway between the lower (power brakes) and the upper (manual brakes) to gain 20% more braking force at the calipers. This would allow you to change the angle of the booster for better hood clearance and still have a good angle on the booster input push rod.
Rodney
Rodney
Rodney
Rodney
This combination; new hole in brake pedal with the dual 8" booster and a stock 1-1/8" master cylinder should provide 20% more braking force. I have question for you. Why did you switch to the dual 8" booster? Were you dissatisfied with the performance of the stock 11" booster?
72cuttys
Brakes/Hydraulic Systems
September 24th, 2021 08:13 AM
LeadFred
October 5th, 2016 12:50 PM
