HARD pedal
Old Sep 12, 2016 | 05:17 PM
Aqua67's Avatar
HARD pedal
Having a problem with brakes on my 67 delta custom. Pedal is very hard and feels as if i dont' even have power brakes. Car is hard to stop unless i really lay on the pedal. Brake booster is new as is the master cylinder. Brakes on all 4's are good and rears have new springs on the self adjusters. Anybody know what the vacuum should be? I can pull the hose out of the booster and not get much of a whoosh.
Old Sep 12, 2016 | 06:15 PM
The hard pedal really sounds like a booster issue. New booster does not necessarily mean a properly working booster.
Old Sep 12, 2016 | 06:25 PM
Tedd Thompson's Avatar
Are you sure all 4 wheels are stopping?Could the rears be the only wheels that are working?
You might try to slide to a stop on gravel and see if all four wheels are trying to lock up. but as mentioned above it very well could be a bad new booster.... Tedd
Old Sep 12, 2016 | 06:34 PM
Originally Posted by Aqua67
425 rough idle
I'm having issue with really rough idle on my 67 olds, 425 4bbl. When it's cold it runs perfect, and no problem driving and cruising along after it's warmed up but when i come to light or idle for any reason it idles very rought as if it were bout to stall.
HARD pedal
Methinks there may be a relation between these two threads, no?
Old Sep 12, 2016 | 07:35 PM
Aqua67's Avatar
[QUOTE=MDchanic;953002]Methinks there may be a relation between these two threads, no?
- Eric[/QUOTE
Other than the obvious (they're both mine). Is this a riddle??
Are you thinking vacuum leak may be the relation between the 2???
Old Sep 12, 2016 | 07:39 PM
Yes.
Old Sep 12, 2016 | 07:42 PM
don71's Avatar
same but different
None or low vacuum means poor power assist=hard pedal.
Old Sep 13, 2016 | 07:31 AM
There is a quick-and-dirty test. Simply disconnect the vacuum hose from the booster and plug it. Obviously you will no longer have power brakes, so be careful. If the engine runs better now, you have a leak in the booster - replace it. If the engine runs the same, fix that problem, as the low vacuum is causing the booster issue.
68oldscutlass
Brakes/Hydraulic Systems
Aug 9, 2012 07:27 AM
RogerC
Apr 14, 2011 04:36 AM
iuhoops83
Oct 7, 2009 09:30 AM
KQQLCAT
Apr 29, 2009 05:51 AM
tarps3
Jun 29, 2008 05:00 AM
