Front wheel hub
Front wheel hub
Hello and a happy new year to everybody.
I was going to order new inner seals for the wheel hubs when I noticed that the seals on the rear and left sides were different.
(This car has front drum brakes.)9
One of them was a felt seal with a flange.This one was stamped National 7607.
According to The Rockauto catalog this is the correct seal for front drum brakes.
The other side had a rubber seal with a larger outer diameter.The dimensions on this one are the same as on National 8705S.This seal is for front disk brakes according to Rockauto.
What I am wondering about is if this is the only difference between the hubs for drum and disk brakes.The bearings seems to be the same,but I have to check this more closely.
Looks like the 7607 seal is correct by another parts store here in the US
http://www.autozone.com/autozone/par.../N-jh5l9Z8knb4
Pat
Pat
Apparently the hub with the 7607 seal is an original 68 drum brake hub. The other hub with the 8705 seal appears to be 1969-up. I'm surprised that the 68s use different seals for drum and disk hubs, since the wheel bearings are the same for both. Apparently GM figured this was a stupid idea also, since for 69-up the drum and disk hubs both use the same 8705 seals as well as the same bearings.
7607 is for 1966 back, felt originally but now often come with a rubber lip seal, 2.33" hole in hub for the seal. 8705 is 67-74 A body, Nova, etc. 2.40" hole. Spindle size is the same. These seals are for drum brakes; presumably discs take the same but IDK.
marxjunk
February 24th, 2015 06:45 PM
akins2000
February 14th, 2012 01:09 PM
