front to rear brake line installation?
Old Mar 15, 2008 | 09:02 PM
gutlass69's Avatar
My dad was talking to some guys at work about installing brake lines for my cutlass. One of the guys who also did a cutlass restore told him its impossible to install a new brake line set without taking the body off of the frame. Is this true? Down the line, if I keep the car, we planned to take it off the frame but not right away. And we didn't plan on taking it off the frame just to put in some brake lines.
Old Mar 16, 2008 | 06:36 AM
I assume you're mainly talking about the front-to-back line. The rest are all pretty easy to get to. Unfortunately, the factory installed this line to the frame before the body, so at best, it's VERY difficult to do it with the body in place. I've only done it in sections myself (hand-bending parts store sections of line and using a coupler). At a minimum you'd need to drop the trans crossmember and temporarily support the trans with a floor jack. You will probably need to tweak the line somewhat to get it past obstructions then bend it back into place. Not impossible, but not on my list of top ten fun things to do (not to mention the constant rain of rust into your face while you do it).
Old Mar 16, 2008 | 03:24 PM
Oldsguy's Avatar
Past Administrator
.....Not impossible, but not on my list of top ten fun things to do (not to mention the constant rain of rust into your face while you do it).
And it doesn't get any easier the older they get. I did what you described on my '46. Not fun.
gutlass69, Maybe the reason the guy told you it was impossible was because he restored his. I heard the judges get real **** about doing things differently than the factory.
Old Mar 18, 2008 | 04:37 AM
Jim's rare 80's Avatar
Jim's rare 80
As said, not an easy job. If you just want the quick fix, put the new one as close to the old one as you can. Don't remove the old one entirely. If you plan to lift the body at a future date, you will still be able to see the factory original to copy from.
Best of luck.
Old Mar 18, 2008 | 05:35 PM
gutlass69's Avatar
thanks for all the responses!
Del70
Dec 7, 2025 02:13 AM
rkk69olds
Brakes/Hydraulic Systems
May 31, 2014 04:39 PM
Maverick
Jun 26, 2013 08:21 AM
toro455
Jul 6, 2011 11:37 PM
gillbates
May 8, 2010 07:25 PM
