Front Drum Spindles
Front Drum Spindles
While cleaning up my front drums on my 72 Cutlass Supreme, I noticed some wear and galling on the spindle bearing surfaces. Not a lot but enough to give me some concern. One spindle shows about .001" variance while the other shows .0025". See photos. It also appears there is wear on the back bearing surface at the large diameter end of the spindle.
Should I have these cleaned up and use them or should I replace them? I haven't been able to find any new replacement spindles for drums on line. I don't really want to convert to disk as I've already purchased new shoes, cylinders, springs, etc. The only drum spindles I've been able to find are on ebay and I can't tell if they have the same wear as mine or not based on the photos.
Thoughts anyone?
Thoughts anyone?
I've cleaned up similar spindles and used them. I'm not really concerned about the bearing surfaces because there is no relative motion between the inner race and the spindle in normal operation. I'd be more concerned about the surface the seal rubs on. That will tear up the seal. You can get a speedi-sleeve to repair that. I've used them on spindles with no issues.
The outer bearing surface has similar wear but without most of the galling; .001' wear on one and .0025 on the other. Is that more of a concern. Also, do they make the speedi-sleeves for this application or will I just need to source on that fits the spindle large diameter.
Thanks,
Ron
Thanks,
Ron
I would not have a concern at all, the tapered bearings are self centering and ride on the races in the hub. As far as the inner seal, as long as you don't go nuts with the grease and just pack the bearings that sealing surface should be fine.
Thanks for your help!
Ron
Joe, can you expand on the comment above about cleaning up the spindles? Did you have them turned, did you steel wool them, how did you clean them up or am I making this a bigger problem than it is? If it's just the shoulder area I should be concerned about, I'll find a speedi-sleeve that will fit but does that require machining the shoulder to offset the thickness of the sleeve?
Ron
Ron
All of the above is good advice.
If it ever becomes a problem, consider this;
https://www.permatex.com/products/th.../?locale=en_us
For what is seen in the pictures, use a sleeve if needed on the seal area and put it together.
Good luck!!!
Good luck!!!
Good luck!!!
Good luck!!!
Ron
DewChugr
Brakes/Hydraulic Systems
July 27th, 2015 05:09 PM
perro
September 3rd, 2007 01:30 PM
