Front Drum Brakes
Front Drum Brakes
I have a 1969 W31 I was going to convert to disc front brakes but have changed my mind. Some time ago I discarded all the front brake parts except one drum with hub attached and second hub without drum for a roller. Now I am trying to track down some original type brakes, maybe from someone that did a disc conversion. Also can are there other cars that would be the same. Trying to stay correct as I can.
Thank you
Thank you
The front spindles interchange on 1964-72 A-body, 68-74 X-body, and 67-69 F-body cars. They all use 9.5" x 2.5" front drum brakes. There are some optical differences in the drums depending on the application. For a real W31 car you probably want them to be correct.
MGBill,
If this helps you out,
I have one N.O.S. Front Brake Drum , I have N.O.S. *** Asbestos *** Brake Shoes, I have all the Brake Hardware , and more…..
Always best to simply call me —- 516 - 485 - 193five —- Craig….
Thank you
Thank you
SteveRob442
Brakes/Hydraulic Systems
July 10th, 2017 10:20 AM
