Disc-Converted 66 Big Car Brake Booster Recommendation?
Old Apr 28, 2019 | 09:20 AM
cfair's Avatar
Spent a good few hours this week tuning the qjet on my 66 Starfire. I couldn't get it to idle correctly.
Turns out the original brake booster has a vacuum leak big enough to throw idle mixture way lean
I converted this Starfire to front discs using 1970 factory rotors & disc brake dual m/c. But the master cylinder is bolted to the original factory (8"?) booster. Which is now leaking. No complaints after 50+ years service.
It looks like going to 9" (per 1970 factory spec) or maybe even 11" would be a good upgrade. It's a big car, so there might be a little more room between the engine and booster than the Cutlass/442.
Does anyone know if an 11" brake booster will fit 65-70 big cars?
With the 66 booster and 70 m/c, the brake pedal feel has always been vague since the disc conversion.
Thanks for any guidance you can offer.
cf
70sgeek
Brakes/Hydraulic Systems
Feb 11, 2019 01:39 PM
aardvark
Dec 23, 2015 07:07 PM
Globeguy
Apr 11, 2014 06:48 AM
smcurro
Oct 14, 2011 12:55 PM
plee3 64Olds
Apr 28, 2011 10:01 AM
