Disc brakes for this boat!!
Old Sep 7, 2018 | 03:24 PM
Fev7's Avatar
Trying to figure out what exactly to order for 4 wheel disc brake Conversion on my newly purchased 64 jetstar 88 . Lots of kits out there but none for exactly this car? Seems it’s an in between a-b body setup? Any help would be much appreciated
thanks
kile
Old Sep 8, 2018 | 06:25 AM
Same thing I told you in your other thread. No one makes kits for these. Also, there is no fuzz on the platform - this is a B-body car. The J88 uses the smaller brakes and rear axle from the A-body cars to cut costs. As a result, the front spindles and rear axle housing are unique to the 1964 J88. Do not expect mainstream vendors to even know what a J88 is, much less know the subtleties of how it differs from other B-body cars. You and about three other people are the only ones on the planet looking for these parts. No one makes them.
As I told you before, you will have to fabricate your own if you want to do this. The A-body front rotors will bolt right onto your front spindles. You will need to cut and weld tabs onto the A-body caliper brackets to attach them to your unique J88 spindles. Ironically, since the J88 rear axle housing is actually just a wider version of the Cutlass housing, any rear disk brake kit that bolts to a 64 Cutlass will also bolt to your car.
deejai35
Brakes/Hydraulic Systems
Jul 25, 2015 08:15 PM
wiseguy58
Feb 11, 2010 01:34 PM
wired
Sep 12, 2009 08:11 AM
nh4kidsdad
Feb 12, 2009 04:49 AM
Kaline
Jul 16, 2007 08:33 PM
