So my front brakes are not stopping or either of them right or left will bleed the master cylinder is new the rear brakes bleed on both sides but front two won’t bleed or stop any suggestions or insight could it be the female t distribution block ?
Was the MC bench bled? Is it a single/original reservoir or was it converted to dual master? If dual does it make pressure at the port going to the front?
