Brake woes
Old Aug 31, 2010 | 09:28 AM
Bluehaze43's Avatar
Brake woes
OK, so I had a couple of leaking wheel cylinders in the front of my 68 Delmont, and decided to re-do the front brakes (11" drums all the way around). Before doing so, I had good pedal feel after pumping them a time or two. Now after replacing the shoes, wheel cylinder and adjusters in the front, and bleeding them, I have no pedal.
I am wondering if I somehow introduced air to the rears when stroking out the pedal when bleeding the fronts, did the master cylinder take a poop on me, or what? I never touched the rears, and now with no pedal, I am fearing there is more of an issue than I care to think about.
I think I will try bleeding the entire system first, and then go from there.
Any other thoughts, ideas or suggestions?
Old Aug 31, 2010 | 10:07 AM
Most likely in the course of replacing the wheel cylinders you allowed the master cylinder to drain dry in the front section. You'll need to bleed the M/C first.
5998DownUnder
Ninety-Eight
Apr 19, 2013 05:56 PM
HotRodRacer
Mar 10, 2012 08:43 AM
Joeypete
Brakes/Hydraulic Systems
Jul 4, 2009 10:38 PM
elmo
Dec 11, 2006 06:18 PM
Redog
Nov 15, 2006 05:20 AM
