Brake lines install
Old Oct 6, 2023 | 09:41 AM
Tancuda's Avatar
Brake lines install
Hi all, changing the brake lines from master cylinder to block on frame under brake booster on my friend's 71 442 (front disk brake).
I want to be sure the lines were routed right before I buy and change them.
The rear port on the block is a 1/4" hose that was connected th the rear port on the master cylinder and the front port on the block to the front port
on the master cylider is a 3/16" line.
I noticed that the 1/4" line use 2 different size fitting, is that ok ?
Old Oct 6, 2023 | 10:12 AM
don71's Avatar
same but different
Its been explained before that this is on purpose. This kept any errors on the assembly line down to a minimum. If the fittings were the same, it would cause problems during the assembly process.
Old Oct 6, 2023 | 04:50 PM
Tancuda's Avatar
Thanks, so I should be good.
ourkid2000
Brakes/Hydraulic Systems
33
Apr 11, 2025 08:40 AM
rpinnt
Sep 4, 2018 06:02 AM
Army_Vet
Oct 10, 2016 06:32 AM
Freddy B
Oct 25, 2015 08:49 AM
70special
Oct 2, 2010 05:53 AM
