brake lights stay on
Every now and then i will exit my car and notice the brake lights are stuck on. It's even drained my batter before when i didn't notice it.
I've replaced the brake light switch and still have the same problem, is there any adjustment I can do on the pedal, it seems to have some play in it.
Car is a 1965 Jetstar 88, single master cylinder, manual brakes.
Sounds like your brake light switch is adjusted wrong.
How far do you need to push down the pedal before the lights come on?
If the brake light switch is adjusted properly, it is also possible that you could have a flaw in your signal light switch.
Also yes, I do have something going on with my signal light switch. My right blinker works, but not my left, I wonder if it's related.
Thanks for the reply
I will give that a try. I know lifting the pedal with my tow off the brake switch shuts the lights off. But sometimes just the weight of the pedal turns the brake lights back on.
'71CS
August 17th, 2021 05:14 AM
