Brake conversion
Old September 3rd, 2018, 04:14 PM
rpinnt's Avatar
Brake conversion
Slowly moving forward and I want to run the brake and fuel lines before the body goes onto the frame. I am converting from manual drums to 4 wheel power discs. I have the booster, master cylinder and prop valve for the swap. I will run new lines from the MC/Prop valve to a new split distribution block. Are the stock brake lines the right size or do I need a different size?
rpinnt is offline
Old September 4th, 2018, 06:02 AM
Stock lines should be 3/16" from the M/C to the front brakes, 1/4" from the M/C to the rear rubber hose, and 3/16" from there to the rear wheels. Those sizes are fine. Keep in mind that once you bleed the air out of the system, the diameter of the brake lines is pretty much irrelevant. Only a small amount of fluid is required to move the pistons.
joe_padavano is offline
jaunty75
Brakes/Hydraulic Systems
31
April 12th, 2017 02:45 AM
Army_Vet
October 10th, 2016 06:32 AM
Bitburger
18
November 29th, 2015 01:54 PM
Freddy B
October 25th, 2015 08:49 AM
therobski
September 3rd, 2013 01:41 PM
Quick Reply: Brake conversion
