Brake and clutch bracket
I removed the clutch and brake pedal assembly from my 70 Cutlass.I unhooked the clutch rod that goes through the firewall. Then I disconnected the brake and clutch bracket that bolts to the firewall/master cylinder at one end and undid the two nuts at the other end.There was a shim under each nut.I guess my question is, shouldn't the shims be under the bracket? If not, why didn't they just use a large washer? Hope this makes sense.
My bad.The steering column attaches to the brake/clutch pedal bracket.The shims are between the column attachment bracket and the aforementioned brake/clutch pedal bracket assembly. Sorry, I'm a little new at this!
Giddy
March 10th, 2009 11:37 AM
