Bleeding a Master Cylinder
Old May 20, 2019 | 05:50 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The best way is to put it in a vice and run hoses from both lines into the reservoir, fill with fluid and push the actuator back and forth, correct? It has been years since I have done one. Pretty sure mine is dying, the pedal goes to the floor now and then. I also will need a rear line on the driver's side, the rear wheel cylinders are leaking and the drivers side won't come loose. What thread or is there a reasonable priced preformed line for the back drivers side? Thanks
Old May 20, 2019 | 06:10 AM
boese1978's Avatar
You got it on the MC, make sure it is clamped level.
Old May 21, 2019 | 06:04 PM
Cool, will do.
Oldssupreme
Brakes/Hydraulic Systems
23
Aug 5, 2018 06:00 AM
TheBigBlueBoat
Jan 13, 2016 06:02 AM
OldsmobileKid
Apr 7, 2015 04:50 PM
Erinyes
Jul 10, 2010 11:24 AM
